Hey everyone.
I just wondering is it possible to use UI KIT components and hooks in a CUSTOM UI based project?
I think that you can use both in a single app but you’re limited to using one type per a module.
For instance, your manifest.yml
could look like this:
modules:
confluence:contextMenu:
- key: dictionary
function: main
title: Define word
jira:issuePanel:
- key: todo-panel
resource: main
resolver:
function: resolver
title: Todos
viewportSize: medium
tooltip: Add a todo list
icon: https://developer.atlassian.com/platform/forge/images/issue-panel-icon.svg
function:
- key: resolver
handler: index.handler
- key: main
handler: index.run
resources:
- key: main
path: static/spa/build
permissions:
scopes:
- storage:app
- read:confluence-content.summary
- write:confluence-content
- read:confluence-props
- write:confluence-props
But you couldn’t import the UI Kit components and use them inside of a module that you’re using Custom UI for.
