The Jira Cloud Builds API has a limit on the number of related issues in a request. If I send more than 100 issue keys, I get the error message errors ": [{" message ":" IssueKeys can contain no more than 100 elements. Found 102. "}]
. I tried to split it into multiple queries with the same updateSequenceNumber
, but to no avail. Jira only displays information from the first request in the group.
As I see from the source code of the Jenkins integration plugin (https://github.com/jenkinsci/atlassian-jira-software-cloud-plugin), they simply ignore issues exceeding 100.
Is it going to be changed or do I something wrong?
Thank you
