Error 401 when Setting Issue Properties via Forge: Possible Restrictions on 'ari☁ecosystem::extension' Key?
Hello everyone,
Since it is not possible to activate issue context panels automatically, I have tried to activate them via their issue property. Using ‘ari:cloud:ecosystem::extension/id/environmentId/static/moduleKey’ as a property key, it is possible to activate an issue context of an app with an id, a timestamp and the “collapsed” attribute.
It also works well in postman. But when I try to add this property via Forge (CustomUI and Invocation), I get an error “401”. If I use a different property key for testing, the whole thing works.
Does Atlassian block the PUT endpoint of issue properties when using a key that contains “ari:cloud:ecosystem::extension”?
If not, what could be the reason?
Many thanks in advance
Regards
Adrian
Hi @AdrianSomesan! I see request URLs coming from what I believe is your app on this form:
https://api.atlassian.com/ex/jira/{cloud-id}/rest/api/3/issue/{issue-key}/properties/ari:cloud:ecosystem::extension/{appId}/{environmentId}/static/{extensionKey}
That URL isn’t recognized as matching Get issue property, so the OAuth 2.0 scope check fails. You need to percent-encode the property key path parameter.
Hi @epehrson,
thank you very much for your quick response.
Percent-encoding the property key did indeed work.
Funnily enough, I found the solution this morning and was just about to write it under this topic. So thank you very much :wink:
Regards
Adrian
