Forge Custom Entity Storage: Querying custom entity with partition and range without a where-clause
I am about to use Custom Entity Storage for our app’s use case.
Now I stumbled upon an unknown behavior that still leaves me unclear.
So basically the query results are empty although I should have added entities to the storage.
This is hard to debug, because the custom entity storage is not visible in the app console and I cannot experiment a lot with the entities because the amount I can try is very limited.
I define the entity by manifest like this:
app:
  storage:
    entities:
      - name: entity-test
        attributes:
          timestamp:
            type: integer
          parentUid:
            type: string
          projectId:
            type: string
        indexes:
          - name: by-timestamp-inc-and-project
            range:
              - timestamp
            partition:
              - parentUid
              - projectId
And I add multiple entities like this (simplified):
const key = data.parentUid + ":" + data.projectId + ":" + data.timestamp;
await storage.entity("entity-test").set(key, data);
Which doesn’t fail.
And I Query the entities like this:
const { results } = storage
  .query()
  .index("by-timestamp-inc-and-project", {
    partition: [parentUid, projectId],
  .sort(SortOrder.ASC)
  .getMany();
The query doesn’t fail. The results are empty. But I expect, there should be my entries for the parentUid, projectId combination ordered by timestamp.
I now tried it with .where(WhereConditions.isGreaterThan(0)) in the query and the result set is still empty. :frowning:
Solved: There was actually no entry in the storage. But that was hard to debug. It even actually works without where-clause.
