Forge System token (X-Forge-Oauth-System) Refresh behaviour is not consistent
We receive the Forge system token (X-Forge-OAuth-System) in two different flows:
  1. From Custom UI → Resolver → Remote backend
  2. From a Scheduled Trigger
The tokens received from these two flows are different, which is fine. Additionally, each flow tends to return a same token until they are refreshed, which is also fine.
However, the refresh behaviour differs between the two from what i’ve observed:
  • In the Scheduled Trigger, a new token is issued when the current token has less than ~2 hours of validity remaining.
  • In the Resolver flow, the token is not refreshed until it is very close to expiry (around ~1 minute remaining).
Problem
This mismatch causes an issue where:
  • A relatively fresh token (with longer validity) obtained via the scheduled trigger is stored.
  • Later, when a user interacts with the app, the resolver flow provides a near-expiry token.
  • This near-expiry token overwrites the previously stored token, leading to 401 errors when used shortly after.
Question
What is the recommended approach to handle this scenario? Specifically, how can we prevent a near-expiry token (from the resolver flow) from replacing a token with a longer remaining validity (from the scheduled trigger)?
Is it fine if we decode the tokens and compare the exp field ? Is it reliable ? because the document says OAuth tokens must be treated as opaque : https://developer.atlassian.com/platform/forge/remote/essentials/#oauth-tokens-must-be-treated-as-opaque
Hi @avinashpachva,
imho the best would be to prevent such situations from happening and provide consistent, deterministic behavior. Please vote for this ticket: Jira
You can also add your particular findings if needed.
Best,
Márton
