By “field id” or “field name” how can we get all the selected options from multi select custom field?
also I want to set multiple values to the multi select type “custom field” by using java code.
The Issue object has a getCustomFieldValue method. This method accepts an instance of a CustomField and returns an Object which should be cast to the appropriate Datatype for that CustomFieldType. That is what I would use.
CustomField myMultiSelectField = customFieldManager.getCustomFieldObject(10010L);
List<Option> values = (List<Option>) issue.getCustomFieldValue(myMultiSelectField);
Thanks for your valuable inputs. I have updated the question can you please help me in that?
Can you clarify your post? I am confused.
I want to set values for custom field which is type of “Select List (Multiple Choices)” by java code.
HI Nilesh,
Please check the below link once.
https://developer.atlassian.com/server/jira/platform/performing-issue-operations/
