Hi!
I’m developing a Forge app on my own trial/sandbox site and cannot get a jira:issuePanel to appear on any issue, regardless of template or app.
What I’ve tried, to isolate the cause:
- App A — scaffolded via
forge create→ Jira → Custom UI →jira-issue-paneltemplate, with the static frontend built (npm install --legacy-peer-deps && npm run build). - App B — scaffolded via
forge create→ Jira → UI Kit →jira-issue-paneltemplate, left completely unmodified (default “Hello world!” panel).
Both apps:
- Deploy successfully to the
developmentenvironment (forge deploy, no errors,forge lintclean). - Install successfully (
forge install, targeting the same site, no errors). - Show up correctly under Site settings → Connected apps → Installed apps, tagged
UTV(development), no warnings or error badges. “App info” page shows the correct deployed version, no issues.
What’s broken:
- Neither panel ever appears on any issue, in any project, in any issue type.
- Tested on multiple issues across two separate company-managed Jira Software projects (one with the Epic-level hierarchy, standard work types).
- Tested in a normal browser session AND a fresh incognito/private session (same account) — no difference.
- Browser DevTools (Network tab) show zero requests to the
ecosystemdomain associated with either app’s module when loading an issue page. The onlyecosystem-adjacent request on the page is an unrelated legacy ConnectconnectBackgroundScriptsGraphQL query (returnsedges: []), which fires regardless of these apps. forge tunnelfor either app shows zero incoming requests when reloading an issue page — the local dev server is never hit at all.
Already ruled out:
- App code/template issue — two completely different templates (one hand-edited, one 100% stock) show identical (non-)behavior.
- Manifest errors —
forge lint --verbosereports no issues for either app. - Stale CLI — updated to Forge CLI 14.2.0, redeployed, no change.
- Browser cache / stale session — incognito window, same account, same result.
- Project-level config — checked project “Issue layout” (not relevant, that’s for fields only) and project Settings → “Apps” (empty, nothing to configure there).
This strongly suggests Jira isn’t even attempting to register/load the jira:issuePanel module for these apps on this site, rather than a rendering or permissions error in the app itself.
manifest.yml for App A (Custom UI), for reference:
modules:
jira:issuePanel:
- key: projektlista2-hello-world-panel
resource: main
resolver:
function: resolver
viewportSize: medium
title: projektlista2
icon: https://developer.atlassian.com/platform/forge/images/issue-panel-icon.svg
function:
- key: resolver
handler: index.handler
resources:
- key: main
path: static/hello-world/build
permissions:
scopes:
- read:jira-work
app:
runtime:
memoryMB: 256
architecture: arm64
Has anyone seen this before, or is there a known site-level setting/feature flag that would block jira:issuePanel modules from registering? Any pointers on what else to check would be hugely appreciated.
