Jira Servlet using TemplateRenderer "&quot" problem
I use TemplateRenderer from my Jira servlet. I add my JSON string to the context
as
String json = jsonMapper.writeValueAsString(featuresWithParameters);
context.put(“myjson”, json);
and then render using: templateRenderer.render(templateName, context, resp.getWriter());
I see on the browser side that the JSON comes encoded with “&quot” which causes an exception in JS Json parser.
Is there any way to prevent that encoding so the JS on browser will get “pure” Json string?
Thanks
E
