Hey!
Is there a chance to get the top position in the project side menu for an app specific menu entry? I’ll tried it with the weight attribute in the atlassian-connect.json (setting to ‘0’).
Can you help me?
Thanks.
Regards, Patrick
Hey!
Can you help me?
Thanks.
Regards, Patrick
Hi @Patrick,
There is no extension point corresponding to the blue arrow in the diagram you provided, but you can contribute links a little lower down. See https://developer.atlassian.com/cloud/jira/platform/jira-project-sidebar/ for a guide on contributing to the project sidebar.
Regards,
Dugald
