Expected: Modal is closed. Actual: Modal and Card are closed.
Actions (2):
Open any card.
Open modal from card-back-section (power up).
Click under the modal (on card area)
Expected: Modal is closed. Card is opened. Actual: Modal is opened. Card is closed.
Actions (3):
Open any card.
Press ESC
Actual: nothing happens
Actions (4)
Open any card.
Open iframe popup from card-back-section (power up) with mouseEvent in params.
Click outside of popup
Expected: Popup is closed.
Actions (5)
Open any card.
Press ESC
Note: if you click in the popup window (set focus) and press ESC, the popup will be closed. Note: if you open the date popup, ESC pressing will close the popup regardless of focus
Browser: Google Chrome (Version 79.0.3945.79 (Official Build) (64-bit)) on macOS 10.15.2 (19C57)
Thanks for the very detailed report of these bugs!
This is something our team is aware of and has queued to fix. Once we get the fix live, I’ll let you know. I don’t have an estimated date yet as a lot of folks are out for the holidays. As soon as I have more info, I’ll pass it along.
We have a version of Trello that we believe addresses these issues.
You can give it a try here: Try an alternate version of Trello This will set your session to use the updated version, so keep in mind that if you close the window, you’ll lose this version.
As far as our bug (card is closed if popup is opened) is concerned, I can confirm that the problem has been solved in the recent production version (as well as in the build provided via the link).
