Power up - Interacting with Card layout
Hey is it possible to interact anyhow with card’s layout applying custom background color etc.? I’d like to develop something similar to Using the Card Aging Power-Up | Trello | Atlassian Support
Yes, there is! There is a chrome extension that changes the colors of Trello cards that you might want to take inspiration from: Card Colors for Trello - Chrome Web Store
Hey @Jireh thanks but that’s a chrome extension not a Trello power up :slight_smile:
I was hoping that maybe I could somehow interact with cover card prop? (I think that’s how aging works :thinking: )
Ah I see, my mistake. Unfortunately no, I don’t believe there is a way to interact with the color of the card. If your power-up depends on adding distinct visual elements to a card, I might suggest using colored labels to serve that purpose.
Please let us know if you have any other questions!
