Hi All,
I am trying to display the icon for an issue in my forge custom ui react app using an img tag. To do this I use the issue->fields->issuetype->iconUrl
value for the img src prop. This works well for stories, but fails to load for epics (Chrome says blocked:csp).
Looking at source, I see that the story icon url was transformed at some point from:
https://site.atlassian.net/rest/api/2/universal_avatar/view/type/issuetype/avatar/10315?size=medium
to
https://api.atlassian.com/ex/jira/guid/rest/api/2/universal_avatar/view/type/issuetype/avatar/10315?size=medium
But the icon url for Epics does not get transformed, and is different from the story one:
https://site.atlassian.net/images/icons/issuetypes/epic.svg
Am I doing something wrong, is this a limitation in the Forge platform, and is there a workaround or another way of displaying the Issue type’s corresponding icon?
Thanks.
