Hello Daz,
following part of our atlassian-plugin.xml is responsible for our “Tabs”.
<!-- Tabs Macro -->
<xhtml-macro key="vw-tabs" name="vw-tabs"
class="${project.groupId}.TabsMacro" documentation-url="${vw.doc.path}/GW Tabs Makro"
icon="/download/resources/${project.groupId}.${project.artifactId}/images/tabs-logo.png">
<description key="${project.groupId}.${project.artifactId}.vw-tabs.desc" />
<category name="formatting" />
<device-type>mobile</device-type>
<parameters>
<parameter name="active-tab-index" type="string" default="0" />
<parameter name="orientation" type="enum" default="horizontal">
<value name="horizontal" />
<value name="vertical" />
</parameter>
<parameter name="languages" type="string" default="none" />
<parameter name="userLanguageEnabled" type="boolean" />
</parameters>
</xhtml-macro>
<web-resource key="tabs-desktop-resources" name="tabs-desktop-resources">
<transformation extension="js">
<transformer key="jsI18n" />
</transformation>
<transformation extension="soy">
<transformer key="soyTransformer" />
</transformation>
<resource type="download" name="tabs.css" location="/css/tabs.css" />
<resource type="download" name="tabs-soy.js" location="/soy/tabs.soy" />
<resource type="download" name="tabs.js" location="js/tabs.js" />
<resource type="download" name="tabs-desktop.js" location="js/tabs-desktop.js" />
<context>atl.confluence.macros.vw-tabs.desktop</context>
</web-resource>
<web-resource key="tabs-mobile-resources" name="tabs-mobile-resources">
</transformation>
</transformation>
<resource type="download" name="theme-mobile.css" location="/css/theme-mobile.css" />
<resource type="download" name="tabs-mobile.js" location="js/tabs-mobile.js" />
<resource type="download" name="VWAGTheAntiqua-Regular.woff" location="/fonts/VWAGTheAntiqua-Regular.woff" />
<resource type="download" name="VWAGTheSans-Regular.woff" location="/fonts/VWAGTheSans-Regular.woff" />
<!--<dependency>com.atlassian.auiplugin:ajs</dependency>--><!--Necessary because of its css-->
<dependency>com.atlassian.auiplugin:jquery-all</dependency>
<dependency>com.atlassian.auiplugin:aui-tabs</dependency>
<dependency>com.atlassian.auiplugin:aui-navigation</dependency>
<context>atl.confluence.macros.vw-tabs.mobile</context>
</web-resource>
and then we have following maven pom.xml-part:
<plugin>
<groupId>com.atlassian.maven.plugins</groupId>
<artifactId>maven-confluence-plugin</artifactId>
<version>${amps.version}</version>
<extensions>true</extensions>
<configuration>
<compressResources>false</compressResources><!-- !!!! needs to be switched off, because there is an issue with GW-Tabs not rendered correctly mobile, when switched on !!!! -->
<productVersion>${confluence.version}</productVersion>
<productDataVersion>${confluence.data.version}</productDataVersion>
</configuration>
</plugin>
The css is there in target/classes. Thats not the problem. I think more that compressResources seems to be used in a double way.
If you need some more info about the tabs-implementation, please let me know.
I’m going to provide some build-logs below.
Best regards
Tobias Franz
compressResources=false
C:\Anaconda3\Library\bin\java.exe -Dmaven.home=C:\atlassian-plugin-sdk-6.3.12\apache-maven-3.2.1 -Dclassworlds.conf=C:\atlassian-plugin-sdk-6.3.12\apache-maven-3.2.1\bin\m2.conf "-javaagent:C:\Program Files\JetBrains\IntelliJ IDEA 2018.3.4\lib\idea_rt.jar=64603:C:\Program Files\JetBrains\IntelliJ IDEA 2018.3.4\bin" -Dfile.encoding=UTF-8 -classpath C:\atlassian-plugin-sdk-6.3.12\apache-maven-3.2.1\boot\plexus-classworlds-2.5.1.jar org.codehaus.classworlds.Launcher -Didea.version2019.1.3 -s C:\atlassian-plugin-sdk-6.3.12\apache-maven-3.2.1\conf\settings.xml -DskipTests=true clean package
[INFO] Scanning for projects...
[INFO]
[INFO] Using the builder org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder with a thread count of 1
[INFO]
[INFO] ------------------------------------------------------------------------
[INFO] Building GW Base Macros Plugin 7.15.17
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ vw-base-macros-plugin ---
[INFO] Deleting C:\projects\CTOARCH\trunk\confluence-5.6.5\vw-base-macros-plugin\target
[INFO]
[INFO] --- maven-confluence-plugin:6.3.21:compress-resources (default-compress-resources) @ vw-base-macros-plugin ---
[INFO]
[INFO] --- maven-resources-plugin:3.1.0:resources (default-resources) @ vw-base-macros-plugin ---
[WARNING] Using platform encoding (UTF-8 actually) to copy filtered resources, i.e. build is platform dependent!
[INFO] Copying 100 resources
[INFO]
[INFO] --- maven-confluence-plugin:6.3.21:filter-plugin-descriptor (default-filter-plugin-descriptor) @ vw-base-macros-plugin ---
[INFO] Using 'UTF-8' encoding to copy filtered resources.
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ vw-base-macros-plugin ---
[INFO] Changes detected - recompiling the module!
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO] Compiling 39 source files to C:\projects\CTOARCH\trunk\confluence-5.6.5\vw-base-macros-plugin\target\classes
[INFO] /C:/projects/CTOARCH/trunk/confluence-5.6.5/vw-base-macros-plugin/src/main/java/de/vw/confluence/base/macros/PlatformAssembler.java: C:\projects\CTOARCH\trunk\confluence-5.6.5\vw-base-macros-plugin\src\main\java\de\vw\confluence\base\macros\PlatformAssembler.java uses unchecked or unsafe operations.
[INFO] /C:/projects/CTOARCH/trunk/confluence-5.6.5/vw-base-macros-plugin/src/main/java/de/vw/confluence/base/macros/PlatformAssembler.java: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-confluence-plugin:6.3.21:generate-rest-docs (default-generate-rest-docs) @ vw-base-macros-plugin ---
[INFO]
[INFO] --- maven-resources-plugin:3.1.0:testResources (default-testResources) @ vw-base-macros-plugin ---
[INFO] skip non existing resourceDirectory C:\projects\CTOARCH\trunk\confluence-5.6.5\vw-base-macros-plugin\src\test\resources
[INFO]
[INFO] --- maven-confluence-plugin:6.3.21:filter-test-plugin-descriptor (default-filter-test-plugin-descriptor) @ vw-base-macros-plugin ---
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ vw-base-macros-plugin ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-confluence-plugin:6.3.21:unit-test (default-unit-test) @ vw-base-macros-plugin ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-confluence-plugin:6.3.21:copy-bundled-dependencies (default-copy-bundled-dependencies) @ vw-base-macros-plugin ---
[INFO] Unpacking C:\Users\tfz\.m2\repository\de\vw\utils\vw-utils\2.4.0\vw-utils-2.4.0.jar to C:\projects\CTOARCH\trunk\confluence-5.6.5\vw-base-macros-plugin\target\classes with includes "" and excludes "atlassian-plugin.xml,META-INF/MANIFEST.MF,META-INF/*.DSA,META-INF/*.SF"
[INFO] Unpacking C:\Users\tfz\.m2\repository\com\google\code\gson\gson\2.8.2\gson-2.8.2.jar to C:\projects\CTOARCH\trunk\confluence-5.6.5\vw-base-macros-plugin\target\classes with includes "" and excludes "atlassian-plugin.xml,META-INF/MANIFEST.MF,META-INF/*.DSA,META-INF/*.SF"
[INFO]
[INFO] --- maven-confluence-plugin:6.3.21:copy-test-bundled-dependencies (default-copy-test-bundled-dependencies) @ vw-base-macros-plugin ---
[INFO]
[INFO] --- maven-confluence-plugin:6.3.21:generate-manifest (default-generate-manifest) @ vw-base-macros-plugin ---
[INFO]
[INFO] --- maven-confluence-plugin:6.3.21:generate-test-manifest (default-generate-test-manifest) @ vw-base-macros-plugin ---
[INFO]
[INFO] --- maven-confluence-plugin:6.3.21:validate-manifest (default-validate-manifest) @ vw-base-macros-plugin ---
[INFO] Manifest found, validating...
[INFO] Manifest validated
[INFO]
[INFO] --- maven-confluence-plugin:6.3.21:jar (default-jar) @ vw-base-macros-plugin ---
[INFO] Building jar: C:\projects\CTOARCH\trunk\confluence-5.6.5\vw-base-macros-plugin\target\gw-base-macros-plugin-7.15.17.jar
[INFO]
[INFO] --- maven-confluence-plugin:6.3.21:generate-obr-artifact (default-generate-obr-artifact) @ vw-base-macros-plugin ---
[INFO] Skipping OBR generation... no OSGi bundle manifest instructions found in pom.xml
[INFO]
[INFO] --- maven-confluence-plugin:6.3.21:validate-test-manifest (default-validate-test-manifest) @ vw-base-macros-plugin ---
[INFO]
[INFO] --- maven-confluence-plugin:6.3.21:test-jar (default-test-jar) @ vw-base-macros-plugin ---
[INFO] BUILD SUCCESS
[INFO] Total time: 59.833 s
[INFO] Finished at: 2019-06-05T14:45:00+01:00
[INFO] Final Memory: 65M/560M
Process finished with exit code 0
compressResources=true:
C:\Anaconda3\Library\bin\java.exe -Dmaven.home=C:\atlassian-plugin-sdk-6.3.12\apache-maven-3.2.1 -Dclassworlds.conf=C:\atlassian-plugin-sdk-6.3.12\apache-maven-3.2.1\bin\m2.conf "-javaagent:C:\Program Files\JetBrains\IntelliJ IDEA 2018.3.4\lib\idea_rt.jar=64652:C:\Program Files\JetBrains\IntelliJ IDEA 2018.3.4\bin" -Dfile.encoding=UTF-8 -classpath C:\atlassian-plugin-sdk-6.3.12\apache-maven-3.2.1\boot\plexus-classworlds-2.5.1.jar org.codehaus.classworlds.Launcher -Didea.version2019.1.3 -s C:\atlassian-plugin-sdk-6.3.12\apache-maven-3.2.1\conf\settings.xml -DskipTests=true clean package
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Compiling javascript using YUI
[INFO] 23 Javascript file(s) were minified into target directory C:\projects\CTOARCH\trunk\confluence-5.6.5\vw-base-macros-plugin\target\classes
[INFO] 14 CSS file(s) were minified into target directory C:\projects\CTOARCH\trunk\confluence-5.6.5\vw-base-macros-plugin\target\classes
[INFO] Compressing XML files
[INFO] 1 XML file(s) were minified into target directory C:\projects\CTOARCH\trunk\confluence-5.6.5\vw-base-macros-plugin\target\classes
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Total time: 9.742 s
[INFO] Finished at: 2019-06-05T14:49:55+01:00
[INFO] Final Memory: 83M/540M
