I want to develop a Confluence Plugin, so I tried to set up the Atlassian SDK.
I have a newly installed Ubuntu VM for this, with JRE 10.0.2.
I followed these instructions to get started:
https://developer.atlassian.com/server/framework/atlassian-sdk/install-the-atlassian-sdk-on-a-linux-or-mac-system/
https://developer.atlassian.com/server/confluence/write-a-simple-confluence-blueprint-plugin/
atlas-version shows:
ATLAS Version: 6.3.10
ATLAS Home: /usr/share/atlassian-plugin-sdk-6.3.10
ATLAS Scripts: /usr/share/atlassian-plugin-sdk-6.3.10/bin
ATLAS Maven Home: /usr/share/atlassian-plugin-sdk-6.3.10/apache-maven-3.2.1
AMPS Version: 6.3.15
Executing: /usr/share/atlassian-plugin-sdk-6.3.10/apache-maven-3.2.1/bin/mvn --version -gs /usr/share/atlassian-plugin-sdk-6.3.10/apache-maven-3.2.1/conf/settings.xml
Java HotSpot(TM) 64-Bit Server VM warning: Ignoring option MaxPermSize; support was removed in 8.0
Apache Maven 3.2.1 (ea8b2b07643dbb1b84b6d16e1f08391b666bc1e9; 2014-02-14T18:37:52+01:00)
Maven home: /usr/share/atlassian-plugin-sdk-6.3.10/apache-maven-3.2.1
Java version: 10.0.2, vendor: Oracle Corporation
Java home: /usr/lib/jvm/jre-10.0.2
Default locale: en_US, platform encoding: UTF-8
OS name: "linux", version: "4.15.0-29-generic", arch: "amd64", family: "unix"
After running: atlas-run everthing looks fine:
[INFO] [talledLocalContainer] INFO: Deployment of web application directory /home/maike/Documents/AtlasDev/Confluence/simplebp/target/container/tomcat8x/cargo-confluence-home/webapps/manager has finished in 28 ms
[INFO] [talledLocalContainer] Jul 31, 2018 8:48:10 AM org.apache.coyote.AbstractProtocol start
[INFO] [talledLocalContainer] INFO: Starting ProtocolHandler ["http-nio-1990"]
[INFO] [talledLocalContainer] INFO: Starting ProtocolHandler ["ajp-nio-8009"]
[INFO] [talledLocalContainer] Jul 31, 2018 8:48:10 AM org.apache.catalina.startup.Catalina start
[INFO] [talledLocalContainer] INFO: Server startup in 17625 ms
[INFO] [talledLocalContainer] Tomcat 8.x started on port [1990]
[INFO] confluence started successfully in 54s at http://ubuntu:1990/confluence
[INFO] Type Ctrl-D to shutdown gracefully
[INFO] Type Ctrl-C to exit
But the service /confluence has not been startet.
So I went to the Tomcat Manager and tried to start it.
I got the message: FAIL - Application at context path /confluence could not be started
The log in the Terminal where I executed atlas-run shows:
[INFO] [talledLocalContainer] INFO: HTMLManager: start: Starting web application '/confluence'
[INFO] [talledLocalContainer] Jul 31, 2018 8:52:10 AM org.apache.catalina.loader.WebappLoader buildClassPath
[INFO] [talledLocalContainer] INFO: Unknown loader jdk.internal.loader.ClassLoaders$AppClassLoader@2c8d66b2 class jdk.internal.loader.ClassLoaders$AppClassLoader
[WARNING] [talledLocalContainer] log4j:WARN No such property [bufferedIO] in com.atlassian.confluence.logging.ConfluenceHomeLogAppender.
[INFO] [talledLocalContainer] 2018-07-31 08:52:11,112 INFO [http-nio-1990-exec-2] [com.atlassian.confluence.lifecycle] contextInitialized Starting Confluence 6.7.1 [build 7601 based on commit hash d9a7d86ddd6172b1b5a38b9e600c8b90c362def3] - synchrony version 2.1.0-release-confluence_6.5-1a01ab2d
[INFO] [talledLocalContainer] 2018-07-31 08:52:13,547 INFO [http-nio-1990-exec-2] [atlassian.confluence.cluster.DefaultClusterConfigurationHelper] lambda$populateExistingClusterSetupConfig$1 Populating setup configuration if running with Cluster mode...
[INFO] [talledLocalContainer] 2018-07-31 08:52:13,793 INFO [http-nio-1990-exec-2] [core.persistence.hibernate.ConfluenceHibernateConfig] getHibernateProperties STARTED H2 database server at URL jdbc:h2:tcp://localhost:9092//home/maike/Documents/AtlasDev/Confluence/simplebp/target/confluence/home/database/h2db;MVCC=TRUE
[INFO] [talledLocalContainer] 2018-07-31 08:52:13,813 INFO [http-nio-1990-exec-2] [springframework.web.context.ContextLoader] initWebApplicationContext Root WebApplicationContext: initialization started
[INFO] [talledLocalContainer] 2018-07-31 08:52:15,742 ERROR [http-nio-1990-exec-2] [springframework.web.context.ContextLoader] initWebApplicationContext Context initialization failed
[INFO] [talledLocalContainer] java.lang.NoClassDefFoundError: javax/activation/MimetypesFileTypeMap
[INFO] [talledLocalContainer] at java.base/java.lang.Class.getDeclaredMethods0(Native Method)
[INFO] [talledLocalContainer] at java.base/java.lang.Class.privateGetDeclaredMethods(Unknown Source)
[INFO] [talledLocalContainer] at java.base/java.lang.Class.getDeclaredMethods(Unknown Source)
[INFO] [talledLocalContainer] at org.springframework.util.ReflectionUtils.getDeclaredMethods(ReflectionUtils.java:609)
[INFO] [talledLocalContainer] at org.springframework.util.ReflectionUtils.doWithMethods(ReflectionUtils.java:521)
[INFO] [talledLocalContainer] at org.springframework.util.ReflectionUtils.doWithMethods(ReflectionUtils.java:507)
[INFO] [talledLocalContainer] at org.springframework.util.ReflectionUtils.getUniqueDeclaredMethods(ReflectionUtils.java:567)
[INFO] [talledLocalContainer] at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.getTypeForFactoryMethod(AbstractAutowireCapableBeanFactory.java:683)
[INFO] [talledLocalContainer] at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.determineTargetType(AbstractAutowireCapableBeanFactory.java:627)
[INFO] [talledLocalContainer] at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.predictBeanType(AbstractAutowireCapableBeanFactory.java:597)
[INFO] [talledLocalContainer] at org.springframework.beans.factory.support.AbstractBeanFactory.isFactoryBean(AbstractBeanFactory.java:1445)
[INFO] [talledLocalContainer] at org.springframework.beans.factory.support.DefaultListableBeanFactory.doGetBeanNamesForType(DefaultListableBeanFactory.java:445)
[INFO] [talledLocalContainer] at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeanNamesForType(DefaultListableBeanFactory.java:415)
[INFO] [talledLocalContainer] at com.atlassian.confluence.setup.ConfluenceListableBeanFactory.getBeanNamesForType(ConfluenceListableBeanFactory.java:153)
[INFO] [talledLocalContainer] at org.springframework.context.support.PostProcessorRegistrationDelegate.invokeBeanFactoryPostProcessors(PostProcessorRegistrationDelegate.java:101)
[INFO] [talledLocalContainer] at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:678)
[INFO] [talledLocalContainer] at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:520)
[INFO] [talledLocalContainer] at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:444)
[INFO] [talledLocalContainer] at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:326)
[INFO] [talledLocalContainer] at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
[INFO] [talledLocalContainer] at com.atlassian.spring.container.ContainerContextLoaderListener.contextInitialized(ContainerContextLoaderListener.java:32)
[INFO] [talledLocalContainer] at com.atlassian.confluence.setup.ConfluenceBootstrappedContextLoaderListener.contextInitialized(ConfluenceBootstrappedContextLoaderListener.java:39)
[INFO] [talledLocalContainer] at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4842)
[INFO] [talledLocalContainer] at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5303)
[INFO] [talledLocalContainer] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:147)
[INFO] [talledLocalContainer] at org.apache.catalina.manager.ManagerServlet.start(ManagerServlet.java:1284)
[INFO] [talledLocalContainer] at org.apache.catalina.manager.HTMLManagerServlet.start(HTMLManagerServlet.java:666)
[INFO] [talledLocalContainer] at org.apache.catalina.manager.HTMLManagerServlet.doPost(HTMLManagerServlet.java:217)
[INFO] [talledLocalContainer] at javax.servlet.http.HttpServlet.service(HttpServlet.java:648)
[INFO] [talledLocalContainer] at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
[INFO] [talledLocalContainer] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:292)
[INFO] [talledLocalContainer] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207)
[INFO] [talledLocalContainer] at org.apache.catalina.filters.CsrfPreventionFilter.doFilter(CsrfPreventionFilter.java:136)
[INFO] [talledLocalContainer] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240)
[INFO] [talledLocalContainer] at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
[INFO] [talledLocalContainer] at org.apache.catalina.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
[INFO] [talledLocalContainer] at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:212)
[INFO] [talledLocalContainer] at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
[INFO] [talledLocalContainer] at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:614)
[INFO] [talledLocalContainer] at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
[INFO] [talledLocalContainer] at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
[INFO] [talledLocalContainer] at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616)
[INFO] [talledLocalContainer] at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
[INFO] [talledLocalContainer] at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:528)
[INFO] [talledLocalContainer] at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1099)
[INFO] [talledLocalContainer] at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:670)
[INFO] [talledLocalContainer] at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1520)
[INFO] [talledLocalContainer] at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1476)
[INFO] [talledLocalContainer] at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
[INFO] [talledLocalContainer] at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
[INFO] [talledLocalContainer] at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
[INFO] [talledLocalContainer] at java.base/java.lang.Thread.run(Unknown Source)
[INFO] [talledLocalContainer] Caused by: java.lang.ClassNotFoundException: javax.activation.MimetypesFileTypeMap
[INFO] [talledLocalContainer] at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1332)
[INFO] [talledLocalContainer] at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1166)
[INFO] [talledLocalContainer] ... 57 more
[INFO] [talledLocalContainer] 2018-07-31 08:52:15,747 ERROR [http-nio-1990-exec-2] [ContainerBase.[Catalina].[localhost].[/confluence]] log Exception sending context initialized event to listener instance of class com.atlassian.confluence.setup.ConfluenceBootstrappedContextLoaderListener
[INFO] [talledLocalContainer] 2018-07-31 08:52:15,751 INFO [http-nio-1990-exec-2] [atlassian.confluence.plugin.PluginFrameworkContextListener] contextInitialized Initialising plugin system
[INFO] [talledLocalContainer] 2018-07-31 08:52:15,751 ERROR [http-nio-1990-exec-2] [atlassian.confluence.plugin.PluginFrameworkContextListener] contextInitialized Error initialising plugin manager: null
[INFO] [talledLocalContainer] java.lang.NullPointerException
[INFO] [talledLocalContainer] at com.atlassian.spring.container.ContainerManager.getComponent(ContainerManager.java:33)
[INFO] [talledLocalContainer] at com.atlassian.confluence.plugin.PluginFrameworkContextListener.getPluginSystemLifecycle(PluginFrameworkContextListener.java:190)
[INFO] [talledLocalContainer] at com.atlassian.confluence.plugin.PluginFrameworkContextListener.contextInitialized(PluginFrameworkContextListener.java:70)
[INFO] [talledLocalContainer] Jul 31, 2018 8:52:15 AM org.apache.catalina.core.StandardContext startInternal
[INFO] [talledLocalContainer] SEVERE: One or more listeners failed to start. Full details will be found in the appropriate container log file
[INFO] [talledLocalContainer] SEVERE: Context [/confluence] startup failed due to previous errors
[INFO] [talledLocalContainer] 2018-07-31 08:52:15,759 ERROR [http-nio-1990-exec-2] [ContainerBase.[Catalina].[localhost].[/confluence]] log Exception sending context destroyed event to listener instance of class com.atlassian.confluence.plugin.PluginFrameworkContextListener
[INFO] [talledLocalContainer] at com.atlassian.confluence.plugin.PluginFrameworkContextListener.contextDestroyed(PluginFrameworkContextListener.java:148)
[INFO] [talledLocalContainer] at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4889)
[INFO] [talledLocalContainer] at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5526)
[INFO] [talledLocalContainer] at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:224)
[INFO] [talledLocalContainer] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:159)
Did someone know what I am missing here?
Thanks in advance!
