atlas-create-jira-plugin
Executing: /Applications/Atlassian/atlassian-plugin-sdk-8.0.16/apache-maven-3.5.4/bin/mvn com.atlassian.maven.plugins:jira-maven-plugin:8.0.2:create -gs /Applications/Atlassian/atlassian-plugin-sdk-8.0.16/apache-maven-3.5.4/conf/settings.xml
[INFO] Scanning for projects...
[INFO]
[INFO] ------------------< org.apache.maven:standalone-pom >-------------------
[INFO] Building Maven Stub Project (No POM) 1
[INFO] --------------------------------[ pom ]---------------------------------
[INFO]
[INFO] --- jira-maven-plugin:8.0.2:create (default-cli) @ standalone-pom ---
[INFO] Google Analytics Tracking is enabled to collect AMPS usage statistics.
[INFO] Although no personal information is sent, you may disable tracking by adding <allowGoogleTracking>false</allowGoogleTracking> to the amps plugin configuration in your pom.xml
[INFO] Sending event to Google Analytics: AMPS:jira - Create Plugin
[INFO] using stable product version: 7.13.0
[INFO] using stable data version: 7.13.0
Define value for groupId: : [ERROR] Error making tracking request
java.net.SocketException: Connection reset
at java.net.SocketInputStream.read (SocketInputStream.java:210)
at java.net.SocketInputStream.read (SocketInputStream.java:141)
at java.io.BufferedInputStream.fill (BufferedInputStream.java:246)
at java.io.BufferedInputStream.read1 (BufferedInputStream.java:286)
at java.io.BufferedInputStream.read (BufferedInputStream.java:345)
at sun.net.www.http.HttpClient.parseHTTPHeader (HttpClient.java:735)
at sun.net.www.http.HttpClient.parseHTTP (HttpClient.java:678)
at sun.net.www.http.HttpClient.parseHTTP (HttpClient.java:706)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0 (HttpURLConnection.java:1569)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream (HttpURLConnection.java:1474)
at java.net.HttpURLConnection.getResponseCode (HttpURLConnection.java:480)
at com.dmurph.tracking.JGoogleAnalyticsTracker.dispatchRequest (JGoogleAnalyticsTracker.java:464)
at com.dmurph.tracking.JGoogleAnalyticsTracker.access$100 (JGoogleAnalyticsTracker.java:76)
at com.dmurph.tracking.JGoogleAnalyticsTracker$1.run (JGoogleAnalyticsTracker.java:431)
According to this thread this command might solve your problem:
atlas-create-jira-plugin -Dallow.google.tracking=false
Thanks @sven.schatter it’s working now with your suggested command.
