requestConfluence DELETE space prop by ID now returns TypeError: Failed to construct 'Response': Response with null body status cannot have body
Hello,
in our delete space property function using forge/bridge requestConfluence worked fine in production. With the new deploy now suddenly there is this error with no changes made around this function.
Could the error be on the side of the forge/bridge requestConfluence DELETE method?
Thank you for any tips.
const deleteSpaceProp = async (space, propertyId) => {
   setIsToggleLoading(true);
    const res = await requestConfluence(
      `/wiki/api/v2/spaces/${space.id}/properties/${propertyId}`,
        method: "DELETE",
   setIsToggleLoading(false);
Uncaught (in promise) TypeError: Failed to construct 'Response': Response with null body status cannot have body
    at X (https://confluence-v1-canary.prod.atl-paas.net/master/41157.3yDfj6EKpQ.js:80:1032)
    at async Object.fetchProduct (https://confluence-v1-canary.prod.atl-paas.net/master/41157.3yDfj6EKpQ.js:80:8088)
    at async https://confluence-v1-canary.prod.atl-paas.net/master/41157.3yDfj6EKpQ.js:74:3676
    at fe.error (https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:122172)
    at Object.<anonymous> (https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:129945)
    at JSON.parse (<anonymous>)
    at o (https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:129804)
    at ke (https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:129957)
    at s.on (https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:134617)
    at je (https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:134754)
    at https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:140740
    at e.try (https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:113224)
    at https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:140537
