Toggle Issue Panel per project
I can limit the displayConditions of issuePanel Docs
I was wondering if it’s possible to toggle visibility by project (Not from manifest level. something similar to using admin page to dynamically achieve this.
Is this possible?
Hi @RoryStandley ,
Welcome to the developer community.
I can’t think of a solution for you based on Forge’s current capabilities.
Regards,
Dugald
Thanks, @dmorrow for now the app I am making is for internal use only so it’s not too much bother for me, but just curious if this is something that is relevant to what Forge should be capable of in the future?
Thanks
Rory
Hi @RoryStandley ,
Yes, this seems appropriate to Forge.
Regards,
Dugald
