Unable to create Issue using a Issue Field Module
I am not able to create an issue using issue field Module.
API - /rest/api/3/issue – POST
Here is request Json for Multi-Select Value-
   "fields": {
   	"issuetype": {
   		"id": "10012"
   	"project": {
   		"id": "10015"
   	"summary": "Laptop HP 9th Gen",
   	"com.xxxx-xxx-xx-app__tally-multi-select-field": [{
   		"id": 1,
   		"value": "item1"
Here is error
    "errorMessages": [],
    "errors": {
        "com.acis.itam-itam-app__tally-multi-select-field": "The list contains an invalid value"
Hi @ChakreshTiwari,
Here is a solution:
   "fields": {
   	"issuetype": {
   		"id": "10012"
   	"project": {
   		"id": "10015"
   	"com.xxxx-xxx-xx-app__tally-multi-select-field": ["1","2"]
