Webhook with JQL and custom issue property not triggering
I’m building a connect app, and want to receive webhooks when certain issues are updated. In my app I’ve added an indexed property, and I can query this successfully using JQL in the UI. The property looks like this:
  "my_app": {"linked": 1, "key": 12345}
Querying for “linked” issues works fine in the UI, using this query.
issue.property[my_app].linked = 1
But when I add this to a webhook (either created manually or via REST) it doesn’t trigger.
The docs say
any indexed issue property can be queried
Why isn’t my webhook triggering? It works fine if I create one manually without any JQL.
Thanks
OK, slight update. I managed to get the webhook to trigger by changing the filter to:
issue.property[my_app].linked = "1"
Even though linked is registered as a number in the index, and it works fine without quote in the UI.
However, this only works for a webhook registered through either the app descriptor, or created manually. It still doesn’t work for ones created through the API. Ideally I want to create them through the UI so that I can put my own parameters (non-JIRA parameters) in the URL. Is this going to be possible?
Thanks
