I have a Jira plugin built against Jira 7.2.2 with Atlassian SDK 6.2.14.
When I run atlas-mvn package
I get a Jar file of ~5,5 Mb.
When I run a Jira instance with atlas-run
and run atlas-mvn package
after that I get a Jar file of ~100 Kb. Both plugins seem to work fine when installed on a local Jira instance.
Smaller jar contains only class files that were created by me. Bigger jar also includes dependencies from pom.xml not marked as provided
Can someone please explain what kind of magic happens when the plugin is being packaged providing two different sets of *.class files and which dependencies should actually be packaged with the plugin?
Below is the contents of my pom.xml:
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>xxx</groupId>
<artifactId>xxx</artifactId>
<version>1.0.0-SNAPSHOT</version>
<organization>
<name>xxx</name>
<url>xxx</url>
</organization>
<name>xxx</name>
<description>xxx</description>
<packaging>atlassian-plugin</packaging>
<dependencies>
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-api</artifactId>
<version>${jira.version}</version>
<scope>provided</scope>
</dependency>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.10</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>com.atlassian.plugin</groupId>
<artifactId>atlassian-spring-scanner-annotation</artifactId>
<version>${atlassian.spring.scanner.version}</version>
<scope>compile</scope>
</dependency>
<dependency>
<artifactId>atlassian-spring-scanner-runtime</artifactId>
<scope>runtime</scope>
</dependency>
<dependency>
<groupId>javax.inject</groupId>
<artifactId>javax.inject</artifactId>
<version>1</version>
</dependency>
<dependency>
<groupId>com.atlassian.jwt</groupId>
<artifactId>jwt-plugin</artifactId>
<version>1.6.2</version>
</dependency>
<dependency>
<groupId>org.springframework</groupId>
<artifactId>spring-context</artifactId>
<version>4.1.6.RELEASE</version>
</dependency>
<dependency>
<groupId>com.atlassian.sal</groupId>
<artifactId>sal-api</artifactId>
<version>3.0.7</version>
</dependency>
<dependency>
<groupId>commons-logging</groupId>
<artifactId>commons-logging</artifactId>
<version>1.2</version>
</dependency>
<dependency>
<groupId>com.atlassian.templaterenderer</groupId>
<artifactId>atlassian-template-renderer-api</artifactId>
<version>1.3.1</version>
</dependency>
<dependency>
<groupId>com.atlassian.plugins.rest</groupId>
<artifactId>atlassian-rest-common</artifactId>
<version>1.0.2</version>
</dependency>
<dependency>
<groupId>com.sun.jersey</groupId>
<artifactId>jersey-client</artifactId>
<version>1.8-atlassian-15</version>
</dependency>
<!-- WIRED TEST RUNNER DEPENDENCIES -->
<dependency>
<groupId>com.atlassian.plugins</groupId>
<artifactId>atlassian-plugins-osgi-testrunner</artifactId>
<version>${plugin.testrunner.version}</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.ws.rs</groupId>
<artifactId>jsr311-api</artifactId>
<version>1.1.1</version>
</dependency>
<dependency>
<groupId>com.google.code.gson</groupId>
<artifactId>gson</artifactId>
<version>2.2.2-atlassian-1</version>
</dependency>
<dependency>
<groupId>org.mockito</groupId>
<artifactId>mockito-all</artifactId>
<version>1.8.5</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>com.sun.xml.bind</groupId>
<artifactId>jaxb-impl</artifactId>
<version>2.2.1.1</version>
</dependency>
</dependencies>
<build>
<plugins>
<plugin>
<groupId>com.atlassian.maven.plugins</groupId>
<artifactId>maven-jira-plugin</artifactId>
<version>${amps.version}</version>
<extensions>true</extensions>
<configuration>
<productVersion>${jira.version}</productVersion>
<productDataVersion>${jira.version}</productDataVersion>
<enableQuickReload>true</enableQuickReload>
<enableFastdev>false</enableFastdev>
<instructions>
<Atlassian-Plugin-Key>${atlassian.plugin.key}</Atlassian-Plugin-Key>
<Export-Package>xxx,</Export-Package>
<Import-Package>org.springframework.osgi.*;resolution:="optional", org.eclipse.gemini.blueprint.*;resolution:="optional", *;version="0";resolution:=optional</Import-Package>
<Spring-Context>*</Spring-Context>
</instructions>
</configuration>
</plugin>
<plugin>
<artifactId>atlassian-spring-scanner-maven-plugin</artifactId>
<executions>
<execution>
<goals>
<goal>atlassian-spring-scanner</goal>
</goals>
<phase>process-classes</phase>
</execution>
</executions>
<configuration>
<scannedDependencies>
<dependency>
<artifactId>atlassian-spring-scanner-external-jar</artifactId>
</dependency>
</scannedDependencies>
<verbose>false</verbose>
</configuration>
</plugin>
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-compiler-plugin</artifactId>
<configuration>
<source>1.8</source>
<target>1.8</target>
</configuration>
</plugin>
</plugins>
</build>
<properties>
<jira.version>7.2.2</jira.version>
<amps.version>6.2.11</amps.version>
<plugin.testrunner.version>1.2.3</plugin.testrunner.version>
<atlassian.spring.scanner.version>1.2.13</atlassian.spring.scanner.version>
<atlassian.plugin.key>${project.groupId}.${project.artifactId}</atlassian.plugin.key>
<testkit.version>6.3.11</testkit.version>
</properties>
</project>
