With atlas-run, 40 plugins do not load. with ./jira-start.sh all works well
i have a running instance of jira and also using atlas-run, with atlas-run no plugins load, 40 plugins show as not installed. the web page shows that the plugins failed to install. if i manually install the plugin in my running instance as an admin, the plugin gets installed successfully. my working instance sends webhooks and has some issues. is my existing instance conflicting with my atlas-run? when i use atlas-run, the same issue happens my other instance of jira is running or if it is not running. atlas-run-standalone successfully runs. the web page shows the following:
System plugins failed to start: We haven’t been able to start all the required system plugins
We couldn’t start the following plugins:
  • Jira Projects Plugin (com.atlassian.jira.jira-projects-plugin)
  • Atlassian OAuth Consumer Plugin (com.atlassian.oauth.consumer)
  • Atlassian Navigation Links Plugin (com.atlassian.plugins.atlassian-nav-links-plugin)
  • Atlassian Jira - Plugins - OAuth Service Provider SPI (com.atlassian.jira.oauth.serviceprovider)
  • Atlassian Jira - Plugins - Project Config Plugin (com.atlassian.jira.jira-project-config-plugin)
  • Applinks - Plugin - Core (com.atlassian.applinks.applinks-plugin)
  • Atlassian OAuth Service Provider Plugin (com.atlassian.oauth.serviceprovider)
  • Embedded Gadgets Plugin (com.atlassian.gadgets.embedded)
  • Gadget Directory Plugin (com.atlassian.gadgets.directory)
  • Atlassian Plugins - JavaScript libraries (com.atlassian.plugin.jslibs)
  • Atlassian Jira - Plugins - Gadgets Plugin (com.atlassian.jira.gadgets)
  • Atlassian Jira - Plugins - Global Issue Navigator (com.atlassian.jira.jira-issue-nav-plugin)
  • Atlassian JIRA - Plugins - File viewer plugin (com.atlassian.jira.jira-fileviewer-plugin)
  • Atlassian Pretty URLs Plugin (com.atlassian.prettyurls.atlassian-pretty-urls-plugin)
  • Atlassian JIRA - Plugins - Quick Edit Plugin (com.atlassian.jira.jira-quick-edit-plugin)
  • Atlassian OAuth Admin Plugin (com.atlassian.oauth.admin)
  • Atlassian REST - Module Types (com.atlassian.plugins.rest.atlassian-rest-module)
  • Atlassian Jira - Plugins - REST Plugin (com.atlassian.jira.rest)
  • Opensocial Plugin (com.atlassian.gadgets.opensocial)
  • atlassian-servlet-plugin (com.atlassian.web.atlassian-servlet-plugin)
  • Atlassian Jira - Plugins - Look And Feel Logo Upload Plugin (com.atlassian.jira.lookandfeel)
  • Gadget Spec Publisher Plugin (com.atlassian.gadgets.publisher)
  • Atlassian Jira - Plugins - OAuth Consumer SPI (com.atlassian.jira.oauth.consumer)
  • Atlassian Jira - Plugins - SAL Plugin (com.atlassian.sal.jira)
  • Gadget Dashboard Plugin (com.atlassian.gadgets.dashboard)
