403 error when using POST call for issue transition
I am getting a 403 issue when using the API Transition issue
POST /rest/api/3/issue/{issueIdOrKey}/transitions) endpoint
This is for my Connect on Forge App.
atlassian-connect.json permissions are - "scopes": [ "read", "act_as_user", "write" ]
The Forge manifest has the below permissions
scopes: [ "read:connect-jira" , "write:issue:jira"]
403 Error
Hi @ajay,
Does this work when adding the write:issue.property:jira to the Forge manifest?
According to the doc, the following scopes are required:
OAuth scopes required : write:issue:jira , write:issue.property:jira
While you are at this, you might want to switch to the OAuth scopes: write:jira-work instead. I know that the documentation has not been updated yet but the deprecation has been stopped.
For reference:
Cheers,
Caterina
Hi @CaterinaCurti ,
I tried modifying the manifest by adding write:issue.property:jira as well using the write:jira-work with no success. I still get 403 as the response code :pensive:
