I am wondering what the best way is to establish a relation between a data object and users. For instance, I want to store a list of users required to perform some action on a page as a JSON object in the properties of the page.
Should I store the usernames? As far as I know the username of a person can be changed if required. This would break my link.
Should I store the user key? Is the key immutable? In practice, the key seems to be much less convenient than the username when working with the Confluence Java API.
Any other option?
Thanks for any tip!
