Confusion regarding "Issue Field Template" for Issue Field Module
Under the Issue Field module reference there is a section called “Issue Field Template” that indicates we can provide a custom template to render select field options.
Does this mean we can provide our own HTML for the field (and handle what fields are shown to the user dynamically) or am I misunderstanding the purpose of this option?
The only template currently supported is “link” (see the documentation), which allows you to provide your own URL clicking the option will redirect to.
Please raise a feature request in the ACJIRA project if you would like the possibility to define your own HTML.
