Create Issue Dialog filling the summary and description does not work
I’m trying to launch the issue creation dialog passing the summary and description parameters and it doesn’t work.
JIRA.Forms.createCreateIssueForm(
      pid: 10200,
      issueType : 10100,
      summary: "Summary",
      decription: "Description"
).asDialog().show()
The dialog opens, but the summary and description fields are not filled in and there is no error in the console.
I have seen in the network tab of the chrome devtools, that the dialog is called and it only passes the issue type and the project id as a parameter.
That could be happening?
Thanks in advance.
How did you find this component/documentation?
As far as I can see from the code, it only takes pid and issueType.
You probably have to set those fields in the dialog using JS
We currently bind a function to the event ‘dialogContentReady’ before calling the show method. Within this method we do modify the input elements manually. In addition, we use a unique id in asDialog to not cause a conflict with other dialog (make sure that the opened Dialog has this id)
.asDialog({id: 'somethingUniqueOrGenerated'})
I’m not sure about this, but should check switching issueTypes
If anyone has a better solution, let us know so that we could change it to something better
I have found it in the following topic:
And the names of the fields I have based on the following documentation.
https://confluence.atlassian.com/jirakb/how-to-create-issues-using-direct-html-links-in-jira-server-159474.html
Currently I am doing this, using the ‘dialogContentReady’ event and filling the value from javascript to the summary and description fields. But I would have liked to do it through the component.
It looks to me like this JavaScript component is meant to just display a create issue dialogue, and expects the user to enter details such as description.
To fill it programmatically, dialogContentReady seems like a good choice
I am currently also looking for a way to populate inputs, text areas and dropdown with predefined values via JS. Did you find a working solution? If yes could you please share an exmaple.
This may be a bit old, but I just found a possible solution that may work a bit cleaner (Not yet tested in a lot of Jira Versions)
This will init the create issue screen with a specific issuetype, summary and a custom field (in my case story points)
window.requirejs(
	['jira/inline-issue-create/prefillable-create-issue-dialog', 'jira/jquery/deferred'],
	(prefillableCreateIssueDialog, Deferred) => {
		const initialValuesDefer = new Deferred();
		const createIssueForm = prefillableCreateIssueDialog.createPrefillableCreateIssueForm(initialValuesDefer);
		createIssueForm.pipe((form) => {
			const b = form.asDialog();
			b.show();
			return b;
		initialValuesDefer.resolve({
			prefilledFields: {
				pid: 10000, //ProjectId
				issuetype: 10001,
				summary: 'test',
				customfield_10105: 15,
//Edit: Fixed project and issue type parameter
