Dialog2 - footer issue in create issue as modal
I have a Custom Field with a custom description - a link that opens a Dialog2.
It works fine in Jira 8.22 but makes a strange issue in Jira 9.4. → I getting a double footer in create issue as a modal , but works fine in create issue as a full screen (attached a screenshots).
This is the code inside the Description of the Custom Field:
<a id="dialog-show-button">{Some-Text}</a>
<section id="demo-dialog" class="aui-dialog2 aui-dialog2-small aui-layer" role="dialog" aria-hidden="true">
    <header class="aui-dialog2-header">
        <h2 class="aui-dialog2-header-main">{Some-Text}</h2>
        <button class="aui-dialog2-header-close" aria-label="close">
            <span class="aui-icon aui-icon-small aui-iconfont-close-dialog"></span>
        </button>
    </header>
    <div class="aui-dialog2-content">
		<p>{Some-Text}</p>
    </div>
    <footer class="aui-dialog2-footer">
        <div class="aui-dialog2-footer-actions">
            <button id="dialog-submit-button" class="aui-button aui-button-primary">OK</button>
        </div>
    </footer>
</section>
<script>
AJS.$("#dialog-show-button").on('click', function(e) {
    e.preventDefault();
    AJS.dialog2("#demo-dialog").show();
AJS.$("#dialog-submit-button").on('click', function (e) {
    e.preventDefault();
    AJS.dialog2("#demo-dialog").hide();
</script>
GalZemah,
You didn’t happen to get a fix for this?
