Entry point "resolver" for extension could not be invoked as it does not exist
I’m building my custom field type in UI Kit 2 and getting resolver could not be invoked error
Structure:
src
├── frontend
│ ├── context-config.jsx
│ ├── edit.jsx
│ └── index.jsx
├── index.js
└── resolvers
└── index.js
manifest.yaml:
modules:
  function:
    - key: proxy-functions
      handler: index.handler
  jira:customFieldType:
    - key: <key>
      name: New Custom Field Type
      description: A hello world custom field.
      type: string
      view:
        render: native
        resource: main
        experience:
          - issue-view
          - portal-view
      edit:
        resource: edit
        render: native
        isInline: true
        resolver:
          function: proxy-functions
        experience:
          - issue-create
          - issue-transition
          - issue-view
          - portal-request
      contextConfig:
        resource: config
        layout: basic
        render: native
resources:
  - key: main
    path: src/frontend/index.jsx
  - key: edit
    path: src/frontend/edit.jsx
  - key: config
    path: src/frontend/context-config.jsx
src/index.js:
export { handler } from './resolvers';
src/resolvers/index.js:
import Resolver from '@forge/resolver';
const resolver = new Resolver();
resolver.define('autocomplete', async ({ payload }) => {
    const q = (payload?.q || '').trim();
    if (!q) return { suggestions: [] };
    return { suggestions: [{ text: `${q} Example Ave` }] };
export const handler = resolver.getDefinitions();
invoking it from edit.js
const data = await invoke('autocomplete', { q, max: MAX_RESULTS });
Error:
edit.js:2 autocomplete error Error: Entry point "resolver" for extension "key" could not be invoked as it does not exist or does not reference a function or endpoint
    at invoke (https://jira-frontend-bifrost.prod-east.frontend.public.atl-paas.net/assets/async-forge-ui-custom-field-extension.af095280.js:90:23716)
    at async https://jira-frontend-bifrost.prod-east.frontend.public.atl-paas.net/assets/async-forge-ui-custom-field-extension.af095280.js:90:57651
Error: Entry point "resolver" for extension "address-custom-field-type-custom-field-type-ui-kit-2-hello-world" could not be invoked as it does not exist or does not reference a function or endpoint
    at he.error (https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:131452)
    at Object.<anonymous> (https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:139225)
    at JSON.parse (<anonymous>)
    at Oe.o (https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:139084)
    at Oe (https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:139237)
    at Me.s.on (https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:143897)
    at Me (https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:144034)
    at https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:150020
    at e.try (https://forge.cdn.prod.atlassian-dev.net/global-bridge.js:2:122504)
seems like I tried all things possible but still can’t figure it out.
Any ideas much appreciated.
For everyone that’s struggling with same issue resolver should be defined on customfieldtype level and not on view/edit level
modules:
    - key: address-custom-field-type-custom-field-type-ui-kit-2-hello-world
      name: Address Custom Field Type
      type: string
      resolver:
