I have an automation rule for writing a comment when I change every status.
It worked normally before I install my plugin ( Issue Panel
But after I install my plugin, the comment is still generated by the automation rule but I need to reload the page to see it.
I try to install some samples plugin with another position( Issue Activity, Issue glance) and automation worked normally.
So I think the problem with Issue Panel.
