Forge SQL: Enable sql.storageApi again for ORM usage
In Forge Dev Den “Working with Forge SQL” you have shown a beautiful way to use Forge SQL via “drizzle orm”. I tried it out and loved it from the very start.
The integration of drizzle was made possible via method sql.storageAPI.
With @forge/sql version 2.3.0 that method is suddenly made private, so the integration is broken now.
Please make that method public again, it seems to be still working the right way.
It makes working with Forge SQL so much easier.
Thank you very much!!
Hi! If you’re looking for an alternative way to use Drizzle ORM with Forge SQL, you can try my solution: forge-sql-orm.
It allows you to integrate Drizzle ORM seamlessly with the latest version of @forge/sql:
import { drizzle } from "drizzle-orm/mysql-core";
import { forgeDriver } from "forge-sql-orm";
const db = drizzle(forgeDriver);
This should work with the most recent @forge/sql.
