I would like to post a json body to a webtrigger. I couldn’t find any peace of information on how to do this. I’ve also checked via debugging the standard hello world example if anything is passed to “runSync”/“runAsync”.
Question: I can I access the request from within “runSync”/“runAsync”? #codegeist
Thanks.
Hi @SvenLauterbach ,
Your should be able to POST JSON to a webtrigger like you would to any REST API endpoint that accepts the POST method.
If you’re posting from a NodeJS runtime, then perhaps use node-fetch as follows:
fetch(your-webtrigger-url, {
method: 'post',
body: JSON.stringify(your-object-to-post),
headers: { 'Content-Type': 'application/json' },
.then(etc);
Can you share some code to help us debug your issue.
Regards,
Dugald
Hi Dugald,
sorry for phrasing the question ambiguous. Its not about sending a post request, but accessing the information from the request in the webtrigger. The synchronous trigger generated by “forge create” is the following snippet:
exports.runSync = () => {
const result = buildOutput(Math.random());
return result;
The question is, how can I access the json from the body your snippet posted to the webtrigger? Like is there a global object i can use?
const result = buildOutput(request.body.propertyOfInterest);
return result;
Or is there a parametet which is passed to the “unSync” method?
exports.runSync = (request) => {
return result;
So how can I access the information from the http request (which triggers the webtrigger) in my runSync() function?
Yes, a request parameter is passed to the runSync method. The following should work:
exports.runAsync = (request) => {
const postBody = JSON.parse(request.body);
const propertyOfInterest = postBody. propertyOfInterest;
Regards,
Dugald
Roaan
August 1, 2021, 11:56pm
5
HI @SvenLauterbach
The following typescript interface definition should help you out.
interface WebTriggerRequest {
body: string;
headers: {[headerName: string]: string[]};
method: string;
path: string;
queryParameters: {[paramName: string]: string[]};
The request is documented here on the web-trigger/request page
tbinna
May 27, 2022, 10:39am
6
@Roaan curious where this type definition is from and if you know a way to access it in app code (via @forge/api or similar)?
If not, it would be good if the WebTriggerRequest type could be exposed in the Forge API package so apps can type web trigger functions accordingly.
