I’ve been using the above - it provides the functionality for adding values to a card in Trello, and then provides a running total in the top banner area.
My problem is when I removed one of the numeric fields from a card, it still remains behind, but instead of displaying the previous field name, it says ‘undefined’.
I would like to clear all of history this app has left in my Trello account so I can start from fresh. Any help would be appreciated.
Thanks, Martyn
@MartynHale Welcome!
It looks like we both mailed the developer of the Power-Up and they got back with the following:
I’m going to try and take a look at this bug over the weekend when I have time, and hopefully I’ll be able to get a quick fix up. In the meantime, go to your board’s sidebar menu, click Costello > Edit Power-Up Settings, and check that there are no extra cost fields listed besides Total Cost - there may be a “hidden” item in the menu if a cost field was created with no title.
Hey all! Jeremy, creator of Costello here. I believe I’ve fixed the bug that was causing this issue. In addition, if anyone finds that their Costello cost data is in a bad state, I’ve added a Reset Cost Fields option to the Costello Power-Up Settings menu.
Hi, I know this is an old thread but Im looking for help with Costello - I want archived cards to not be included in the total at the top of the page or alternatively only show the total by Label, which can be selected but cant seem to be made default view. I would apreciate any help
Thanks Linda
Hi @LindaMcKendrick
For the Costello team to be aware of your feature request, we recommend you reach out to Costello support through the Contact Support button on the Power-Up page (Trello).
