How to add Comment in JIRA issue through groovy script using curl?
I have done some curl operations like below:
def gitlabCommitStatus(String status) {
    def gitlapUrl = "'$gitlabAPI/$projectId/statuses/$sha?state=$status'";
    def commitData = "--data 'description=$commitStatusDesc' --data 'target_url=$env.BUILD_URL'";
    def commitStatus = "curl -s --request POST --header 'PRIVATE-TOKEN: $gitlabToken' $gitlapUrl $commitData";
    executeCommand(commitStatus);
    if (status != 'running' && checkCommitMessage() && isProtectedBranch()) {
        status = status == 'failed' ? "Failure" : "Success";
        runShell('gulp ci-report --status ' + status);
As same above, i want use below curl in here which is suggested by JIRA team in below support ticket
Ticket - Atlassian Support
Curl command -
curl --request POST \
  --url 'https://https://organization.atlassian.net/rest/api/3/issue/<issue-key>/comment' \
  --user '<email_address>:<API_Token>' \
  --header 'Accept: application/json' \
  --header 'Content-Type: application/json' \
  --data '{
  "body": {
    "type": "doc",
    "version": 1,
    "content": [
        "type": "paragraph",
        "content": [
            "text": "Atlassian Test",
            "type": "text"
above curl works fine in linux terminal
