How to add custom tab for issue in Jira Product Discovery project?
Hello Community!
I want to display my custom tab for an issue in the Jira Product Discovery project (see screenshot):
I use this item from atlassian-connect.json (I use custom property and condition):
It works for Software projects, Bug Tracking projects and others, but it doesn’t work for Jira Product Discovery project (not beta). I checked the custom property via REST API and the value is correct, but I don’t see my custom tab.
Are there any limitations for custom tabs, custom panels or project properties in Jira Project Discovery ? I din’t find any mentions in the docs. Is it possible to add the custom tab/custom panel for Jira Product Discovery?
Kind regards
Here is a link to a pinned community post about known limitations of Jira Product Discovery:
According to this post, Connect/Forge apps are not yet supported in JPD.
The word Tab is not mentioned as a limitation in the link provided.
Hi @MarkHortman – As of two years ago (when this answer was posted), there was a known limitation that Forge and Connect apps were just entirely unsupported. Tabs would not have been mentioned explicitly, because no features at all were supported.
Unfortunately, I cannot verify whether that is still the case, because the link is giving me a 403 error at the moment. (Possibly because I am working remotely via a VPN?)
Update:
I have access to the page again. This limitation is still listed:
Support for Marketplace apps and API
Atlassian Connect, Forge / Marketplace apps aren’t working in Jira Product Discovery projects yet, and the API for Jira Product Discovery artecfact isn’t public.
I think Tabs are implicitly included in this limitation.
