Hello, there’s a way to display a leaflet map on a IssuePanel or better on a custom field?
I’ve tried with a Custom UI issue panel with @forge/bridge and https://react-leaflet.js.org but i have
no images on map and this error:
Please be aware of the Valid domain formats, which may be tricky for this particular use case (e.g. the “wildcard domain starting with *” only works for the next level sub-domain, so you might ultimately need to resort to the “generic wildcard to support every domain” if you do not know all possible tile servers upfront.
