How to filter the JIRA Issues by specific versions ? using jql or $filter
I am using the the rest api v2
and i see jql=project=xyz
i would like to filter by specific version.
versions is field of array type, and the array has “name” :“v2”
i tried jql=project=xyz and versions/name=‘v2’
does not work
i also tried with escape character versions/name=‘version1’ did not work
“versions”: [
“self”: https://jira.tools.abc/rest/api/2/version/351752,
“id”: “351752”,
“name”: “v2”,
“archived”: false,
“released”: false
In JQL, the field is called ‘fixVersion’
Refer to the JQL Advanced Search Reference documentation for all the default field names.
