I am pretty new to Forge and so far it seems like only the “function” property allows for rendering on the Issue View (as opposed to custom field edit modal), which is only possible going through the default cli bundler and seems to error out with “ReferenceError: window is not defined” when a ReactDOM render is called.
Is it possible to display the field UI from a resource or in some other way or maybe I’m missing something obvious here?
Hoping for your advice!
