Hello!
I created an empty Jira plugin project using atlas-create-jira-plugin command from the Atlassian Plugin SDK. I run then atlas-integration-test and everything works fine. Then I add just 2 lines to MyComponentWiredTest class:
import java.util.function.Supplier;
Supplier s = this::toString;
Then I run atlas-integration-test again and this time get BUILD FAILURE. Cause:
com.atlassian.plugin.osgi.container.OsgiContainerException: Cannot start plugin: com.atlassian.plugins.atlassian-plugins-osgi-testrunner-bundle
at com.atlassian.plugin.osgi.factory.OsgiPlugin.enableInternal(OsgiPlugin.java:418)
at com.atlassian.plugin.impl.AbstractPlugin.enable(AbstractPlugin.java:287)
at com.atlassian.plugin.manager.PluginEnabler.actualEnable(PluginEnabler.java:130)
at com.atlassian.plugin.manager.PluginEnabler.enable(PluginEnabler.java:107)
at com.atlassian.plugin.manager.DefaultPluginManager.enableDependentPlugins(DefaultPluginManager.java:1248)
at com.atlassian.plugin.manager.DefaultPluginManager.addPlugins(DefaultPluginManager.java:1218)
at com.atlassian.jira.plugin.JiraPluginManager.addPlugins(JiraPluginManager.java:153)
at com.atlassian.plugin.manager.DefaultPluginManager.earlyStartup(DefaultPluginManager.java:597)
at com.atlassian.jira.plugin.JiraPluginManager.earlyStartup(JiraPluginManager.java:119)
at com.atlassian.jira.ComponentManager$PluginSystem.earlyStartup(ComponentManager.java:641)
at com.atlassian.jira.ComponentManager.quickStart(ComponentManager.java:196)
at com.atlassian.jira.ComponentManager.start(ComponentManager.java:165)
at com.atlassian.jira.upgrade.PluginSystemLauncher.start(PluginSystemLauncher.java:47)
at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$postDbLaunch$2(DefaultJiraLauncher.java:154)
at com.atlassian.jira.startup.DefaultJiraLauncher$$Lambda$70/1956872054.run(Unknown Source)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:304)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:199)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:146)
at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$start$0(DefaultJiraLauncher.java:105)
at com.atlassian.jira.startup.DefaultJiraLauncher$$Lambda$15/1147552338.run(Unknown Source)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:31)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:103)
at com.atlassian.jira.startup.LauncherContextListener.initSlowStuff(LauncherContextListener.java:160)
at com.atlassian.jira.startup.LauncherContextListener.initSlowStuffInBackground(LauncherContextListener.java:145)
at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:105)
... 8 filtered
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.osgi.framework.BundleException: Activator start error in bundle com.atlassian.plugins.atlassian-plugins-osgi-testrunner-bundle [125].
at org.apache.felix.framework.Felix.activateBundle(Felix.java:2196)
at org.apache.felix.framework.Felix.startBundle(Felix.java:2064)
at org.apache.felix.framework.BundleImpl.start(BundleImpl.java:955)
at org.apache.felix.framework.BundleImpl.start(BundleImpl.java:942)
at com.atlassian.plugin.osgi.factory.OsgiPlugin.enableInternal(OsgiPlugin.java:399)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 15912
at org.objectweb.asm.ClassReader.readClass(Unknown Source)
at org.objectweb.asm.ClassReader.accept(Unknown Source)
at com.atlassian.plugins.osgi.test.asm.BundleTestScanner.processUrl(BundleTestScanner.java:46)
at com.atlassian.plugins.osgi.test.asm.BundleTestScanner.scan(BundleTestScanner.java:32)
at com.atlassian.plugins.osgi.test.BundleTestClassesActivator.addBundle(BundleTestClassesActivator.java:94)
at com.atlassian.plugins.osgi.test.BundleTestClassesActivator.start(BundleTestClassesActivator.java:68)
at org.apache.felix.framework.util.SecureAction.startActivator(SecureAction.java:645)
at org.apache.felix.framework.Felix.activateBundle(Felix.java:2146)
I’d like to attract attention of the Atlassian test runner team. It is a bug in their component. Although I specified Java 8 level for sources and target and have JDK 8 installed I cannot use Java 8 in wired tests. Please fix it.
My environment:
Windows 8.1
Atlassian Plugin SDK 6.3.7
jdk1.8.0_51
APMS 6.3.14
Jira 7.6.1
atlassian-plugins-osgi-testrunner 1.2.3
maven.compiler.source 1.8
maven.compiler.target 1.8
