Jira useForm Problem
I am trying to use Jira Form from UI kit. However, I am having difficulties on getting the form value and setting the value using Select component. This is the code from my project.
import React, { Fragment, useEffect, useState } from "react";
import ForgeReconciler, {
  Button,
  Heading,
  Inline,
  Label,
  Select,
  Spinner,
  Stack,
  Strong,
  Text,
  Toggle,
  Form,
  FormSection,
  useForm,
  FormHeader,
  RequiredAsterisk,
  FormFooter,
} from "@forge/react";
import { invoke } from "@forge/bridge";
import { storage } from "@forge/api";
import {
  DATE_TIME_OPTIONS,
  DEFAULT_CONFIGURATION,
  STORAGE_KEY_PREFIX,
} from "./constant";
import { format } from "date-fns";
const App = () => {
  const [projectData, setProjectData] = useState([]);
  const [projectKey, setProjectKey] = useState(undefined);
  const [projectConfigState, setProjectConfigState] = useState(null);
  const [isProjectConfigSubmitted, setIsProjectConfigSubmitted] =
    useState(false);
  const [loading, setLoading] = useState(false);
  const { register, handleSubmit, getValues, formState } = useForm();
  const [selectedOptionDate, setSelectedOptionDate] = useState("");
  // state for toggles
  const [isAssigneeVisible, setAssigneeVisible] = useState(false);
  const [isNotifyAssignee, setNotifyAssignee] = useState(false);
  const [isHistoricalAssigneeVisible, setHistoricalAssigneeVisible] =
    useState(false);
  // fetching projects
  const fetchProjects = async () => {
    const data = await invoke("getProjectFromJira");
    setProjectData(data);
  // getting storage Data
  const getStorageConfigData = async () => {
    const data = await storage.get(`${STORAGE_KEY_PREFIX}_${projectKey}`);
    setProjectConfigState(data || DEFAULT_CONFIGURATION);
  const isOptionDateSelected = (value) =>
    projectConfigState &&
    projectConfigState.timeConfig &&
    projectConfigState.timeConfig === value && { defaultSeleted: true };
  const isToggleConfigSelected = (name) =>
    projectConfigState && projectConfigState[name] && { defaultChecked: true };
  useEffect(() => {
    fetchProjects();
    getStorageConfigData();
  }, [projectKey]);
  const onProjectConfigSubmit = async (projectConfig) => {
    // await storage.set(`${STORAGE_KEY_PREFIX}_${projectKey}`, projectConfig);
    // setProjectConfigState(projectConfig);
    // setIsProjectConfigSubmitted(true);
    console.log(projectConfig);
  const RenderProjectPicker = () => {
    return loading ? (
      <Spinner />
    ) : projectData?.length !== 0 ? (
      <Stack space="space.100">
        <Heading as="h4">
          In this Page you can modify<Strong>Issue Health Monitor</Strong>{" "}
          configuration for selected project
        </Heading>
        <Select
          appearance="default"
          options={projectData.map((project) => ({
            label: project.name,
            value: project.key,
          onChange={(e) => {
            setProjectKey(e.value);
      </Stack>
      <Text>No Configurable projects avaliable</Text>
  const renderDateTimeOption = (option) => {
    let label;
    const sampleDate = new Date();
    switch (option[1]) {
      case DATE_TIME_OPTIONS.day:
        label = `Day-month-year: ${format(sampleDate, DATE_TIME_OPTIONS.day)}`;
        break;
      case DATE_TIME_OPTIONS.month:
        label = `Month day, year: ${format(
          sampleDate,
        break;
      case DATE_TIME_OPTIONS.year:
        label = `Year, month day: ${format(
          sampleDate,
        break;
      default:
        label = `Year-month-day: ${format(
          sampleDate,
          DATE_TIME_OPTIONS.default
        break;
    return { label, value: option[0] };
  const getOptions = () => {
    let options = [];
    Object.entries(DATE_TIME_OPTIONS).map((option) => {
      options.push(renderDateTimeOption(option));
    return options;
  const options = getOptions();
  return (
    <Fragment>
      {isProjectConfigSubmitted && (
        <SectionMessage title="Configuration Saved" appearance="confirmation" />
      {!projectKey ? (
        <RenderProjectPicker />
        <Form onSubmit={handleSubmit(onProjectConfigSubmit)}>
          <FormHeader title={"Issue Health Configuration"}>
            Required fields are marked with an asterisk <RequiredAsterisk />
          </FormHeader>
          <FormSection>
            <Select
              {...register("timeConfig")}
              name="timeConfig"
              options={options}
              value={selectedOptionDate}
              onChange={(e) => setSelectedOptionDate(e.value)}
            <Inline space="space.100" alignBlock="center">
              <Toggle
                {...register("isAssigneeVisible")}
                label="Show/hide Assignee"
                name="isAssigneeVisible"
                size="large"
                isChecked={isAssigneeVisible}
                onChange={() => setAssigneeVisible((pre) => !pre)}
              <Label labelFor="isAssigneeVisible">Show/hide Assignee</Label>
            </Inline>
              <Toggle
                {...register("isNotifyAssigneeButtonVisible")}
                label="Show/hide Assignee notification button"
                name="isNotifyAssigneeButtonVisible"
                size="large"
                isChecked={isNotifyAssignee}
                onChange={() => setNotifyAssignee((pre) => !pre)}
              <Label labelFor="isNotifyAssigneeButtonVisible">
              </Label>
            </Inline>
              <Toggle
                size="large"
                {...register("isHistoricalAssigneeVisible")}
                label="Show/hide Historical assignees"
                name="isHistoricalAssigneeVisible"
                isChecked={isHistoricalAssigneeVisible}
                onChange={() => setHistoricalAssigneeVisible((pre) => !pre)}
              <Label labelFor="isHistoricalAssigneeVisible">
              </Label>
            </Inline>
          </FormSection>
          <FormFooter>
            <Button type="submit" appearance="primary">
              Submit
            </Button>
          </FormFooter>
        </Form>
    </Fragment>
ForgeReconciler.render(
  <React.StrictMode>
    <App />
  </React.StrictMode>
Can someone help me out of this problem? Thanks.
Hi! If you create a github repo and put your app code there, it will be much easier to help you.
Thank you so much Alex_sam. Finally, I solved it.
