Hi People,
I’ve got a problem trying to use JSD API 7.6.1 to create a simple incident…
So far, I’m POSTing values and they are recognized OK (summary, description, category), but some other values are from Insight and those are just not recognized…
This is my POST:
$ curl -stderr -u apiuser:*** -H “Content-Type:application/json” -X POST -d ‘{“serviceDeskId”:“1”, “requestTypeId”:“4”, “requestFieldValues”:{“summary”:“LLagos JSD REST API”, “description”:“Ejemplo desde API JSD”, “customfield_10400”:{“id”:“10200”}, “customfield_10318”:[{“value”:“SER-15”}], “customfield_10328”:[{“value”:“SER-1”}], “customfield_10329”:[{“value”:“SER-18”}] }}’ http://…:8080/rest/servicedeskapi/request | python3 -mjson.tool
“errorMessage”: “Su solicitud no pudo ser creada. Compruebe que los campos han sido rellenados correctamente. Ingrese un valor para el campo obligatorio ‘Servicio’ Ingrese un valor para el campo obligatorio ‘Zona’ Ingrese un valor para el campo obligatorio ‘Componente’”,
“i18nErrorMessage”: {
“i18nKey”: “sd.validation.request.creation.failure.required.field”,
“parameters”: [
“Ingrese un valor para el campo obligatorio ‘Servicio’ Ingrese un valor para el campo obligatorio ‘Zona’ Ingrese un valor para el campo obligatorio ‘Componente’”
Sorry for the spanish but it simply says fields “Zona” (cf10318), “Servicio” (cf10328), and “Componente” (cf10329) are just not recognized… not even a “bad format” or “incorrect value” error… it just keeps saying “not here; please add them”…
So, what is the correct format for this?
I’ve also tried what the doc says, that the array should be “requestFieldValues: []” but that throws a very ugly java exception…
$ curl -stderr -u apiuser:*** -H “Content-Type:application/json” -X POST -d ‘{“serviceDeskId”:“1”, “requestTypeId”:“4”, “requestFieldValues”:[{“summary”:“LLagos JSD REST API”, “description”:“Ejemplo desde API JSD”, “customfield_10400”:{“id”:“10200”}, “customfield_10329”:{“value”:“SER-18”}} ]}’ http://…:8080/rest/servicedeskapi/request
<?xml version="1.0" encoding="UTF-8" standalone="yes"?><status><status-code>500</status-code><message>Can not deserialize instance of java.util.LinkedHashMap out of START_ARRAY token
at [Source: org.apache.catalina.connector.CoyoteInputStream@9aebb53; line: 1, column: 42]</message><stack-trace>org.codehaus.jackson.map.JsonMappingException: Can not deserialize instance of java.util.LinkedHashMap out of START_ARRAY token
at org.codehaus.jackson.map.JsonMappingException.from(JsonMappingException.java:163)
at org.codehaus.jackson.map.deser.StdDeserializationContext.mappingException(StdDeserializationContext.java:219)
at org.codehaus.jackson.map.deser.StdDeserializationContext.mappingException(StdDeserializationContext.java:212)
at org.codehaus.jackson.map.deser.std.MapDeserializer.deserialize(MapDeserializer.java:246)
at org.codehaus.jackson.map.deser.std.MapDeserializer.deserialize(MapDeserializer.java:33)
at org.codehaus.jackson.map.deser.SettableBeanProperty.deserialize(SettableBeanProperty.java:299)
at org.codehaus.jackson.map.deser.BeanDeserializer._deserializeUsingPropertyBased(BeanDeserializer.java:905)
at org.codehaus.jackson.map.deser.BeanDeserializer.deserializeFromObjectUsingNonDefault(BeanDeserializer.java:739)
at org.codehaus.jackson.map.deser.BeanDeserializer.deserializeFromObject(BeanDeserializer.java:683)
at org.codehaus.jackson.map.deser.BeanDeserializer.deserialize(BeanDeserializer.java:580)
at org.codehaus.jackson.map.ObjectMapper._readValue(ObjectMapper.java:2704)
at org.codehaus.jackson.map.ObjectMapper.readValue(ObjectMapper.java:1315)
</stack-trace></status>
Really don’t know what else to try…
Thanks a lot!
