Please follow the below URL for the whole description and investigation done so far.
https://ecosystem.atlassian.net/servicedesk/customer/portal/14/DEVHELP-2552
Hi @nitish.sajwan,
DEVHELP tickets aren’t public so nobody here can see the information in that ticket.
Can you please provide us with a short description here?
I’ve also moved your topic to the correct category here on the developer community.
Cheers,
Peter
So when I am trying to import the plugin project in my eclipse, the pom file shows lots of error.
Attaching screenshot.
But the same project builds and run perfectly when I use atlas-run and atlas-package command via command prompt.
I am using windows machine to perform these actions.
Actions done so far
1)Before importing project I have already run command in command prompt.
I have made the below changes in mvn.bat file
In “atlas-mvn.bat” file comment out the following line:
call set MVN_COMMAND=%%MVN_COMMAND:${mavenPluginName}=%MVN_PLUGIN%%%
Replace it with:
call set MVN_COMMAND=%%MVN_COMMAND:%%
Any updates on this?
Hello @nitish.sajwan,
Are still experiencing problems with this one? Is it safe to assume that the plugin can still be compiled and run properly via CLI and the error/warning is in the IDE only?
Thanks,
Ian
