Hello
I have custom field that extends AbstractMultiCFType in java
In getVelocityParameters method I’m saving selectedFields in list
by doing the following:
//This is saved as global paramaters in the class
private HashMap<Integer, String> selectedAoList= new HashMap<>();
Object value = issue.getCustomFieldValue(field);
for (Ao activeObject: (List<Ao>) value) {
selectedAoList.put(activeObject.getID(), activeObject.getName());
In the edit vm I’m selecting the values chosen in a select html
<select class="select cf-select" multiple="multiple" id="$customField.id" name="$customField.id:selectedValues">
#foreach ($ao in $aoList)
#set($aoValue= "$ao.getName()")
<option value="$ao.getID()"
#if ($selectedAoList.keySet().contains($ao.getID()))
SELECTED
#end
$aoValue
</option>
#end
</select>
However randomly sometimes selected values are rendered (wrongly) according to selected value of different issue.
So when 2 users are editing simultaneously 2 different issues, selected values of the first issue may appear into the second issue’s selected value
Can you assist on the above
