I’ve installed node and docker, but when I run this: npm i -g @forge/cli
I get this error:
npm ERR! command failed
npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c prebuild-install || npm run build
npm ERR! > keytar@7.9.0 build
npm ERR! > node-gyp rebuild
npm ERR! prebuild-install WARN install unable to get local issuer certificate
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@9.1.0
npm ERR! gyp info using node@18.12.1 | win32 | x64
npm ERR! gyp info find Python using Python version 3.9.5 found at “C:\Python3.9.5\python.exe”
npm ERR! gyp http GET https://nodejs.org/download/release/v18.12.1/node-v18.12.1-headers.tar.gz
npm ERR! gyp WARN install got an error, rolling back install
npm ERR! gyp ERR! configure error
npm ERR! gyp ERR! stack FetchError: request to https://nodejs.org/download/release/v18.12.1/node-v18.12.1-headers.tar.gz failed, reason: unable to get local issuer certificate
npm ERR! gyp ERR! stack at ClientRequest. (C:\Program Files\nodejs\node_modules\npm\node_modules\minipass-fetch\lib\index.js:130:14)
npm ERR! gyp ERR! stack at ClientRequest.emit (node:events:513:28)
npm ERR! gyp ERR! stack at TLSSocket.socketErrorListener (node:_http_client:494:9)
npm ERR! gyp ERR! stack at TLSSocket.emit (node:events:525:35)
npm ERR! gyp ERR! stack at emitErrorNT (node:internal/streams/destroy:151:8)
npm ERR! gyp ERR! stack at emitErrorCloseNT (node:internal/streams/destroy:116:3)
npm ERR! gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
npm ERR! gyp ERR! System Windows_NT 10.0.19044
npm ERR! gyp ERR! command “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js” “rebuild”
npm ERR! gyp ERR! cwd C:\Users\dbelew\AppData\Roaming\npm\node_modules@forge\cli\node_modules\keytar
npm ERR! gyp ERR! node -v v18.12.1
npm ERR! gyp ERR! node-gyp -v v9.1.0
npm ERR! gyp ERR! not ok
npm ERR! A complete log of this run can be found in:
npm ERR! C:\Users\dbelew\AppData\Local\npm-cache_logs\2023-01-06T01_10_21_791Z-debug-0.log
Any help would be appreciated.
Thanks!
