Problem with content transformed from ProseMirror Node to CXHTML inside static macro plugin
I’m creating a Cloud plugin that use static macro module. This macro should render a cxhtml content which is transformed from ProseMirror node format do cxhtml by editor-confluence-transformer
But I noticed that some attributes (like table cell colors) are not supported/not interpreted well. For instance:
<table class="wrapped">
  <colgroup>
    <col/>
    <col/>
  </colgroup>
  <tbody>
    <tr>
      <th data-highlight-colour="dark green">
        <p></p>
      </th>
      <th data-highlight-colour="dark teal">
        <p></p>
      </th>
    </tr>
  </tbody>
</table>
will not render in static macro colored cells.
As I suppose currently in static macro module is supported only Confluence Markup version described here:
https://confluence.atlassian.com/doc/confluence-storage-format-790796544.html?_ga=2.50328038.1752924811.1580063874-284999592.1577177842
Are there any plans to extends the capabilities of static macro module, that we are able to support e.g adf format?
