Problems displaying dialog over issue dialog
While developing the application, such an interesting bug was found:
Steps to reproduce:
  1. Open a board
  2. Open an issue, make sure it’s opened as a dialog.
  3. Open a glance panel that is hight enough to be scrollable.
  4. Open any dialog, e.g. “Give feedback”
  5. The glance panel goes outside of the issue dialog.
There is a project here that can be easily reproduced by installing: https://glitch.com/~lowly-sequoia-branch
Hi @AlexeyGritskevich,
Thanks for reporting this. I’ve created [JRACLOUD-74975] Opening a dialog in the issue view results in the glance panel rendering out of place - Create and track feature requests for Atlassian products. to track this problem.
Regards,
Dugald
Hi @dmorrow,
Looks like this issue [JRACLOUD-74975] Opening a dialog in the issue view results in the glance panel rendering out of place - Create and track feature requests for Atlassian products. was closed. However the bug wasn’t fixed.
Could you take a look?
Regards,
Natalya
Hi @natalya,
I spoken to the team. They were unable to reproduce this and thought it may be fixed. They’ve re-opened it now.
Regards,
Dugald
