We are currently working on a feature where the function involves heavy and long-running operations. As a result, the execution time exceeds 25 seconds, causing a function execution timeout issue.
So we are switching the function to Long-running function,However, during the implementation of the long-running function, we are encountering the following issue:
- When running forge deploy
Error: Manifest validation failed: Timeout too long for function capacityResolver. Maximum timeout 25 seconds. (requestId: 8a05d1c8-f49a-417e-889b-3471bbcfd177).
I have attached the Resolver and Consumer modules for reference. let me know if it is correct or if any changes are required.
Hi @KiranVinayagam,
The syntax for defining a queue consumer in the manifest was recently updated. I suspect this may be related?
Instead of resolver property in your consumer module, you now can just define a function directly, like so:
consumer:
- key: queue-consumer
# Name of the queue for which this consumer will be invoked
queue: queue-name
# Function to be called with payload
function: consumer-function
function:
- key: consumer-function
handler: consumer.handler
timeoutSeconds: 600
Do you want to try updating to the new manifest syntax (and updating your consumer to be a regular function rather than a resolver) and seeing if that helps?
cheers,
Tim
In addition to Tim’s advice, also double-check to make sure the function is not referenced by any other modules. If a function is used as a queue consumer and also as the implementation for another module (eg. an event handler), the lowest maximum timeout wins (eg. 25 seconds).
The issue has been resolved as function was referenced by other module.
Thanks for the solution.
cheers,
Kiran
