Trello MCP server unavailable across ChatGPT and Claude — connection failures and possible HTTP 429 errors
Hello Atlassian Community,
I am experiencing recurring connectivity issues with the official Trello MCP server (https://mcp.trello.com/v1).
Observed behavior:
  • Trello works normally through the web interface for reading and editing cards.
  • ChatGPT and Claude both fail to retrieve Trello cards through MCP.
  • After disconnecting Trello from Claude and attempting to reconnect, the authorization flow failed with an error indicating that the Atlassian server was not responding.
  • I have also found community reports mentioning MCP timeouts and HTTP 429 errors around October 21–22, 2026.
The fact that the issue affects two independent AI platforms, while the Trello web interface remains functional, suggests a possible problem with the MCP service or its connection infrastructure.
The public status page has not consistently reflected the reported symptoms.
Has anyone else experienced these failures? Is there a known issue, a workaround, or a recommended way to collect diagnostic information for the Trello MCP team?
I am using the free Trello plan, so I cannot open a standard support ticket.
Any guidance from Atlassian staff or community experts would be appreciated.
Thank you
